brakes pulling - NCRS Discussion Boards
brakes pulling
  • Walt W.
    • November 1, 1998
    • 92
    brakes pulling
    My 67 L71 pulls to the left and squeels when brakes are applied. Pads look OK.
    Car has J56 option w/dual pin calipers. Please share any thoughts on fixing.
    Thanks, Walt Weems
  • Ken Edmunds
    Re: brakes pulling
    Check your right front brake hose for kink or blockage. They eventually swell up internally and act as a one way valve.
    • Louis Kolb
      Re: brakes pulling
      Sounds like the right front rubber brake hose is defective and acting as a check valve. NAPA has them.
      • John O.
        • May 31, 1998
        • 480
        Re: brakes pulling
        Hi Walt
        I had that happen to me on a cavalier and it turned out to be a stuck caliper on one side.It never retracted and stayed against the rotor.So when I applied the brakes, that side grabbed first and pulled the car to one side. I took the caliper and pulled back on the rubber around the pistons and cleaned it real good.After compressing the pistons and putting it back together, it worked fine. The dirt that got in between the piston and rubber stopped it from retracting.
        Hope this helps you...........John
