68 Insulation question - NCRS Discussion Boards
  • Kurt B.
    • July 31, 1996
    • 971
    Does anyone know what the purpose is of the heavy tarpaper like insulating material used under the door sills?
    It seems to run the width of the door sill and is only about 6-8 inches wide so it barely reaches the floor.
    Kurt
  • Jim T.
    • March 1, 1993
    • 5351
    Re: 68 Insulation question
    It has been a lot of years since I have removed a door sill on my FEB built 68 Kurt, but I don't remember any heavy tarpaper under the door sills.
    • John Chesher
      From the location, I would have guess it was to insulate against sidepipe heat. However, I don't think pipes were an option in 68, right? Could it be that the car once had pipes and the owner at the time tried to insulate a little?
      • Steve Wallach
        My Feb. 68 has this, although it's in BAD shape. I would guess it's another attempt at sound / water protection? I would like to know where to get these pieces to replace mine????
        Steve
        • Kurt B.
          • July 31, 1996
          • 971
          My car was not a sidepipe car so I don't think it was for that. I bought the car from the original owner and he did not change anything as he was a purist so I believe it was original. It is like a tar paper but of heavier consistency. I am going to use rubber water shield as roofing contractors use.
          Kurt
          • steve wallach
            NO 68 was a factory side pipe car, so it couldn't have been for that.
            Steve
            • kelly theaker
              i believe if you look at the A.I.M you will find a diagram of the paper you describe and went exactly as described under the rug partialy also . look close and you will find the pic.
