C6...Rear gear upgrade...anyone know - NCRS Discussion Boards
  • Justin B.
    • March 1, 1996
    • 478
    what all is required to make this change? Do I have to have my computer recalibrated? I am in N.C., anyone know of a shop that is good at this type of stuff?
    • 15674
    Re: C6...Rear gear upgrade...anyone know
    What are you talking about? The C6 rear rear suspension hardly needs an "upgrade" other than maybe some alignment tuning and adjustable shocks if you are doing track events.
    • Rob M.
      NCRS IT Developer
      • January 1, 2004
      • 12740
      Must be a April fools day joke ;-)
      Rob.
      NCRS Software Developer
      • Gary Bishop
        Are you asking about changing the gear ratio to higher numbers?
        • Justin B.
          • March 1, 1996
          • 478
          Opps, sorry, what I am asking about is changing the gear ratio from the standard 2:73 to something a little quicker out of the hole. Who does a quality job and is computer calibration necessary?
            • 15601
            Justin,
            I have no particular experience with C6, but any post 1996 vehicle will need a computer update if one changes the rear axle ratio or dramatically changes the tire diameter. The anti-lock brakes will set a malfunction code with either of those changes. In the case of the C6 I suspect the anti-slip regulation and/or the active handling will adversely be affected without a computer reflash. Modern cars are, by design, not so easily modified as the old ones.
            • Clem Z.
              • January 1, 2006
              • 9427
              go over to the corvette forum as the guys
              over there do stuff like this all the time and there will be someone from your area that will know who can do this. this is not cheap about $2500 because you can not just buy the gears,you must buy a complete rear gear assy. it is also about a 8 hour labor to change
