ID Valve Covers - NCRS Discussion Boards
ID Valve Covers
  • Dennis B.
    • May 31, 2004
    • 175
    ID Valve Covers
    I have two Corvette valve covers that have been in my garage for over 35 years. They have the casting flaw through the "O" of Corvette. #3767493 with "Lester" on the inside. What years do these belong to?
  • Kent K.
    • December 1, 1982
    • 1139
    Re: ID Valve Covers
    IIRC late 59 through 67 and varies for HP in each year, not for base 300HP 67. Hope someone either confirms this or provides corrected information. I too have a pair.
    Kent #6201
    Kent
    NCM Founder - Member #718
    • Donald T.
      • September 30, 2002
      • 1319
      Re: ID Valve Covers
      The casting flaw first appeared in mid 66 production. The L79 (350 HP) engine had the aluminum valve covers in 66 and 67. It would fit earlier SB applications, but would not be correct with the casting flaw.
      Don
      • William C.
        • May 31, 1975
        • 6037
        Re: ID Valve Covers
        The casting flaw also got worse in valve covers sold over the counter in the 70's and later. Original '66-67 era covers ave a very fine casting flaw thet is only shightly noticable. Covers sold in the mid-70's and later got so bad the "O" on Corvette was partially filled in.
        Bill Clupper #618
        • Kent K.
          • December 1, 1982
          • 1139
          Kent
          • Terry D.
            • May 31, 1987
            • 2691
            56-59 had staggered holes *NM*
              But...
              early cast aluminum covers used 9-rib construction and low relief Corvette script. He said these were 7-rib covers with staggered mounting holes and high relief script which dates them to the late '58 through early '59 era (before '59 cylinder heads changed to straight across valve cover mounting holes)....
              • Kent K.
                • December 1, 1982
                • 1139
                Re: But...
                Thanks Jack. That's the information I was seeking.
                Kent #6201
                Kent
