68 Master cylinder questions? - NCRS Discussion Boards
  • steve wallach
    What is the date code for a 68 Master Cylinder supposed to read? My car has power brakes, so I know I should have a "PG" code on the front area. The master cylinder that was on the car when I got was an after market part, so I've purchased a rebuilt Delco "PG" unit, there appears to be a 4 diget code stamped in to the front line machined area as the Judging Manual states there should be, but the manual doesn't say how to read the date code? The numbers appear to be 9307? Is that a 69 or a 67 code?
    Steve
    • 43236
    Re: 68 Master cylinder questions?
    steve-----
    It's the 307th day of 1969.
    • steve wallach
      Ok,
      Thanks!
      Steve
      • Daniel S.
        • February 1, 2000
        • 164
        Delco Moraine master cylinders are stamped with julian date. 9307 would be the 307th day of 1969.
