How to ID a Holley Carb? - NCRS Discussion Boards
  • Isaac Tyson
    So I pulled the 750 Holley off my '61 because it was just way to big for the engine. I replaced it with a 600 Edelbrock for now, until I can buy the entire fuel injection system... Anyhow, I was thinking I'd sell the Holley, but I figured I should know a bit about it before dropping it on Ebay...
    What numbers do I need off the carb to ID it? I started looking and there are numbers on just about every part, and at this time, I am far too lazy to copy them all down.
    Can someone give me a head start here?
    -Tyson
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: How to ID a Holley Carb?
    look on the front of the choke housing tower and there should be a "LIST" number. post that number
    • Isaac Tyson
      Is that number 6R 6931 B?
      The other numbers I'm seeing are: 80508 1085
      How many numbers/letters should there be?
      • Isaac Tyson
        Pictures of carb...
        Here is a link to several pictures, sorry, that are not the greatest. I'm still not sure I understand the LIST number... Will it be stamped LIST and the numbers?
        https://home.comcast.net/~kustomcorvette/holley.htm
        Holley Carb
        • Clem Z.
          • January 1, 2006
          • 9427
          80508 is the carb #
          it is a 750 CFM after market over the counter carb. looks like holley has removed the word "LIST" from the part number
          • Isaac Tyson
            Re: 80508 is the carb #
            Thanks for the help. I was hoping by chance it was worth something, but guess not. Thanks again for the help.
            -Tyson
            • Kent K.
              • December 1, 1982
              • 1139
              It's worth smoething to someone ...
              but, the question is, is it worth the same to you AND could you and the interested party agree on the same number of frogskins???
              Kent #6201
              P.S. Everything is worth something to someone.
              Kent
              NCM Founder - Member #718
