62 340 Ignition Timing - NCRS Discussion Boards
  • Greg S.
    • July 31, 1995
    • 243
    I replaced an 8" service replacement harmonic balancer with an original rebuilt finned 8 " balancer. The ring of the service replacement had slipped so initial timing was somewhat guesswork. I re-timed the engine to 13 degrees BTDC on the new balancer using a dial back timing light. The engine seems to want more initial advance. At 13 degrees it gets hotter at idle than before and it wants to run on at shut off. This engine has flat top pistons with a compression ratio of about 9-1. All other components are as original. Considering the lower C.R. how much initial advance can I safely run with this engine. If the engine doesn't knock at 18 degrees why not run more advance?
    Also out of curiosity I checked advance at various RPM using the dial back timing light. Readings were:
    Degrees / RPM
    13 / 800
    14 / 900
    20 / 1100
    23 / 1400
    28 / 2100
    32 / 2400
    34 / 2800
    38 / 3200
    Is this a typical advance curve for a dual point distributor?
  • Terry D.
    • May 31, 1987
    • 2691
    Re: 62 340 Ignition Timing
    Greg
    A couple of questions, are you running the original dual point distributor? Are you sure the dwell is set right, can really alter timing if not. Is the 38 degrees at 3200 the total advance? Not sure when that should peak out but someone with way more knowledge than me, John Hickley hopefully, we jump in and solve that problem
    • Greg S.
      • July 31, 1995
      • 243
      It is a dual point dist. Dwell is set at 29 each point 34 total. I stopped checking advance at 3200 RPM. I think 25 degrees is the total advance expected from the centrifical advance. 13 initial and 25 centrifical adds up to 38 total expected advance. Thats why I stopped at 3200 RPM. I could be wrong.
      • Mike McKown
        I don't see anything wrong with your timing curve. I do suspect your initial timing is off because of uncoordinated timing marks on your new balancer and the timing cover. Use a piston stop to find true TDC and then go from there. Once you find that you'll have your starting point. Then, I'd rev the thing until it stops advancing to find the true total you have in your centrifugal advance.
        If you're lazy like me, you can crank about ten more degrees intial in it and see how it runs. If it's better and it doesn't rattle, you can just about bet your timing marks are off.
          The timing index line on the inertia ring must be exactly intersected by a radial line from the hub keyway that passes through the center of the pulley bolt hole. If so, your timing index line is on the money, and you can go from there. As Mike said, don't stop checking at 3200 - keep revving it until it stops advancing so you know exactly what your total timing is and when it's "all in". Let us know what you find.
          • Greg S.
            • July 31, 1995
            • 243
            Mike, the new balancer has the timing mark in line with the keyway for the crankshaft which I assume is correct. I am not sure about the timing tab on the timing cover. I believe it to be correct for the 340 horse engine but am not certain. The engine really idles better and about 20 degrees cooler when advance is set at 18+ degrees vs 13. I don't have a piston stop but will see if I can get one at local auto store. Is it possible for the distributor to be off a tooth causing this type of problem and still run OK?
            • Mike McKown
              Being off one tooth will not cause this problem. I'm sure you know which wire is #1 but if you're timing light is on the wrong wire, that will cause the problem.
              Sounds like your balancer is okay for an original '62 timing pointer. The piston stop will tell you the rest of the story.
              Just thinking about what you're saying, you may not have a problem at all. Any SHP 283/327 I ever fooled with does like more than 12 degrees at idle. They like 20-25 better but they'll tend to kick back on the starter plus unless you limit the total advance, they will have too much advance. This is why they will idle better with the vac advance pulled in which you do not have.
              • Chris H.
                • April 30, 1990
                • 817
                Here is an original timing cover for a '62 340
                user name /passord is Chenige
                • Greg S.
                  • July 31, 1995
                  • 243
                  I have the same timing cover tab as you. I am going to run more initial advance as Mike indicates. I will try it this weekend and drive to see if it pings or kicks back on the starter.
