Stamppad paint (C3 BB) - NCRS Discussion Boards
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12758
    Hi all,
    Another question regarding my C3 car. Since the car is a pratically untouched (except the sloppy exterior paint) and I posses nearly every specified maintenance bill since 1970 I'm pretty certain the number matching 427 engine is never repainted during its 37 years life. But it appears the stamp pad was originaly painted and never wiped off during the paint process to remove the orange paint. If I remember correctly the stamp pad wipe off was stated as the process taking place during engine painting, so I'm confused and reluctant to remove the paint from the stamp pad.
    My question is: Was the paint process for BB engines any different and should there be paint on the stamp pad?
    Any help would be appreciated since I'm very carefull to change the car making it less original and correct...
    greetings,
    Rob.
    Rob's C3 Weblog
    Rob.
    NCRS Software Developer
  • Mark #28455
    It appears to have been painted later
    The VIN derivative also appears to be painted. That was stamped at St. Louis, so the pad must have been repainted after that.
    Mark
    • Rob M.
      NCRS IT Developer
      • January 1, 2004
      • 12758
      Re: It appears to have been painted later
      Mark (and others),
      Maybe this is a stupid question but could the paint not been stamped into the characters?
      greetings,
      Rob.
      Rob.
      • Mike M.
        • May 31, 1974
        • 8389
        rob: somebody other than a tonowanda employee painted your pad. regards, mike
          • 11644
          Agree. The orange tooks a tad too glossy for Tonawanda applied. I'd suggest the water pump may have been replaced, and then the block was touched up at that time, hitting the paint pad. Overall I wouldn't consider the block paint as entirely original in appearance.
          Patrick
          • Rob M.
            NCRS IT Developer
            • January 1, 2004
            • 12758
            Patrick,
            You do have a point here! My waterpump was indeed replaced in the past (this was mentioned on one of the vintage bills) so very likely at that time someone has done some painting to get that part orange as well. Your suggestion makes perfect sence...
            greetings,
            Rob.
            Rob.
            • Rob M.
              NCRS IT Developer
              • January 1, 2004
              • 12758
              Now I studied some of the other engine blok pictures is surely looks like the waterpump is too shinny indeed. I'll check tomorrow if the stamppad has the same gloss...
              PS Should the intake of this 427/390hp car be orange or aluminium colored?
              thanks all for your reply,
              Rob.
              Rob.
              • Mike E.
                • February 28, 1975
                • 5138
                Rob--
                Your first post indicated that the car was "pretty much untouched" except for exterior paint. Not to rain on your parade, but the photo you show with this post has an awful lot of things that have been "touched". Valve covers, fuel line and filter, hoses, AIR plugs on the exhaust manifold, etc. I always applaud your enthusiasm, and appreciate your work with the registry, but my definition of "untouched" is apparently different.
                Mike
                  • 11644
                  My thoughts too.
                  The orange fuel filter is either a Fram, or someone had WAY too much fun with their can of orange spray paint.
                  Some detailing is in order to make it appear factory correct.
                  Patrick
                  • Mike M.
                    • May 31, 1974
                    • 8389
                    intake shoyuld be chevy engine orange. mike
                    • Greg L.
                      • March 1, 2006
                      • 2291
                      Rob, the L36 intake originaly was natural aluminum.
                      • Mike S.
                        • March 1, 2005
                        • 125
                        Patrick,the dents in the radiator tank at upper hose area.in the picture.is this normal? my 71 454 car has the same dents. thanks Mike
                          • 11644
                          If you're talking about the natural aluminum tank strapped to the right inner fender, it should not have dents in it. It seems to appear to have bad light reflection in Rob's picture, rather than a dent.
                          Patrick
                          • Mike S.
                            • March 1, 2005
                            • 125
                            no iam talking about the black tank part of the radiator on drivers side that the upper hose ataches to .the side of radiator.thanks. Mike
                            • Mark #28455
                              factory bevel
                              Just checked 2 of my cars, the original radiators appear to have a triangular bevel (like the valve cover on a 1967) at the drivers front corner. My 69 is otherwise dent-free, the 1970 has an additional small wrinkle or two.
                              Hope this helps,
                              Mark
