RE: 65 vent window for coupe - NCRS Discussion Boards
  • harry nye
    Hello to all. I figure this would be the best place to find this part. I'm sure anyone out there who has a midyear corvette has had the problem of the hinge breaking off the vent window where the glass is attached. My ask is for help, does anyone have a vent window frame in real nice condition or NOS with a perfect untouched hinge without the glass for a 65 coupe driver side. This frame is the one that holds the glass and winds out when turned. Your Help is much appreciated. Thanks Harry
  • Mike M.
    • May 31, 1974
    • 8385
    Re: RE: 65 vent window for coupe
    the frame and the hinge are stainless. remove the glass, drill thru the frame where the two spot weld scars reside. put some stainless wire in your mig and weld them back together thru the two holes you drilled in the frame. get your Baldor buffer out and polish the whole deal. takes about an hour and it'll be perfect. mike
