Aluminum intake: removal of the oil fill tube? - NCRS Discussion Boards
  • Dick G.
    • May 31, 1988
    • 681
    OK, what does one use to remove the old chrome oil fill tube from my 65 350HP aluminum intake. Thanks! Dick Gutman
  • Mike M.
    • May 31, 1974
    • 8389
    Re: Aluminum intake: removal of the oil fill tube?
    go to the woodpile and choose a green locust or oak log about 2" in diameter and about 2 foot long, put it in a lathe, turn one end down to just uinder the ID of the fill tube, insert me oak in tube and jiggle it back and forth tapping the tube with a rubber-headed hammer. have intake in vice and buddy grasping the tube while you tap on tube and rotate mr oak.good luck. mike
    • Philip C.
      • December 1, 1984
      • 1117
      Mikes got a good idea but if you dont have a lathe, and the manifolds off, turn it over and use a flat punch or round stock and just tap it out from the bottom. If its on the car work it back on forth with semi gentle taps with a rubber hammer Phil 8063
        • 43221
        Dick-----
        Keep in mind that if you remove it, you will not be able to re-install it with the same interference (tight) fit that it originally had. These tubes are, basically, a "swaged-in-place" sort of thing. This is a "one-time-only" thing. It is possible to re-establish an interference fit by "knurling", "centerpunching" or otherwise upsetting metal on the manifold machined hole. I've never found these to work very well, though, in the long run---usually the tube gets loose again.
        If you are going to use a new tube and the tube is properly made, it will work ok.
        • Don Izzo
          you can also take the used tube to your local mechanic or muffler shop and ask the guy to use his pipe expander to swell the diameter a few thousanths of an inch and you will again have the press fit you are looking for. Usual cost, a box of Duncan Donuts will "get 'er done"!
