C3 Do'se GM sill make controle arm bushings - NCRS Discussion Boards
  • Rob C.
    • August 31, 2004
    • 144
    Counld Some one tell me if GM still makes controle armbushings, sleeves, bolt and shims. Allso do they make the rubber bushings by the front of the diferential. I did not make the parts department before they closed.
    Thank You,
    Rob
    • 43221
    Re: C3 Do'se GM sill make controle arm bushings
    Rob-----
    I doubt that GM ever actually manufactured these parts, but the parts are still available from GM. The parts, with current GM list prices and number required PER CAR, are shown below. Keep in mind that some of these parts are available only in unit quantities which may exceed what you need. So, if your dealer doesn't stock them, you'll likely have to purchase the entire unit quantity. One way around this is to buy the parts from a Corvette supplier like Dr. Rebuild, Paragon, etc.
    trailing arm bushings (4 required)---GM #3743857----$12.14/each
    bushing plate (4 required)-----------GM #3820418------1.75/each
    retainer (tube) (2 required)---------GM #3819806------6.53/each
    bolt (2 required)---------------------GM #458984------10.03/each
    slotted nut (2 required)--------------GM #3774712------4.09/each
    dif bracket UPPER cushion (1 required)-GM #3788637------12.85/each
    dif bracket LOWER cushion (1 required)-GM #3795333------11.90/each
    • Rob C.
      • August 31, 2004
      • 144
      Thank you Joe I will call tomorrow *NM*
