C2 Horns Weak - NCRS Discussion Boards
C2 Horns Weak
  • Mark
    C2 Horns Weak
    My horns on my C2 are really weak sounding. It started after replacing my turn signal lever and switch. Any suggestions? Ive checked connections and nothing seems to improve it. Any help would be appreciated.
    Mark
  • Mike M.
    • May 31, 1974
    • 8388
    Re: C2 Horns Weak
    problem probably resides in the horns themselves. take em off the car so you can turn the star-headed screw on the horn body(much easier to do on workbench). turn the screw clockwise about an 1/8th turn then counterclockwise 1/4 turn then 1/8th turn clockwise(back to original setting). put 12 volts to the puppy. sometime a light tap on the star-headed screw works wonders. once it starts blowing experiment with slight clockwise and counterclockwise rotations of the screw to get max. decibels. if this doesn't work, may be time to send the horns out for rebuild( new diaphrams and or transformer). good luck, mike
      Re: C2 Horns Weak
      Mark -
      If they were fine before replacing the switch, it's probably a bad ground connection between the cancelling cam brass surface, horn brush assembly, and the end of the "leg" on the horn contact assembly; make sure all those contact surfaces are clean an shiny.
      • Mark P.
        • July 31, 2003
        • 407
        Re: C2 Horns Weak
        Checked everything over and sure enough, it was in the horns. When I pulled the first one out to check it, I found the problem. They were full of water! I left the openings turned slightly up after re-installing them. I cleaned them out and dried them up and they work like a charm again. What a bonehead. Hose me down and call me bubba.
        Thanks for the advice,
        Mark
        Mark Pugmire
        54 Pennant Blue
        56 Cascade Green Dual Quad
        56 Arctic Blue Dual Quad
        66 Nassau Blue 427 L36 Convertible
        67 Marlboro Maroon L79 Coupe
