clock in 62 vette loose - NCRS Discussion Boards
  • John O.
    • May 31, 1998
    • 480
    Hi all.
    When I installed my clock in my 62 vette I set it in the opening and turned it to tighten it in place but it is still alittle loose.Am I missing something here to make it tight?
    Thanks for your help...........John
  • Mike E.
    • February 28, 1975
    • 5138
    Re: clock in 62 vette loose
    Sounds like you're missing the spring ring behind the clock that creates the tension to keep it tight. It's a light piece of spring steel, OD slightly less than the opening of the bezel, ID slightly larger than the OD of the clock.
    • Dennis C.
      NCRS Past Judging Chairman
      • January 1, 1984
      • 2409
      John, If you need one, think a gotta free spare... *NM*
      • Mike M.
        • May 31, 1974
        • 8385
        Re: John, If you need one, think a gotta free spar
        you still trying to peddle your grandma's old pessary springs? mikie
        • Rob Edwards
          Here's a C1 pessary spring for Mike
          For posterity's sake, here's a pic:
