1985 heater water control valve resource - NCRS Discussion Boards
  • Ralph A.
    • May 31, 2002
    • 236
    Does anyone know of a source that has this in stock?
    Ralph
    Ralph Adams
    NCRS: 38137 LA: 112
    Slidell, LA 70461
    1969 350/300 LeMans Blue Conv (restoring)
    1971 350/270 Bridgehampton Blue Conv (top flight)
    1972 350/200 War Bonnet Yellow Conv (restoring)
    2001 Bowling Green Metallic Conv (fun car)
    • 43221
    Re: 1985 heater water control valve resource
    Ralph-----
    I show this part as being currently available from GM, although it may have been recently discontinued. If it's the part I'm thinking it is, it's GM #22532158, aka Delco #15-5372. Chevyland in Shreveport, LA has these in stock. Also, The Last Detail in Atlanta likely has them in stock, too.
    • Ralph A.
      • May 31, 2002
      • 236
      Re: 1985 heater water control valve resource - tha
      Chevyland had the part you identified but that is not the one I needed. I need a part that started with 1012. They directed me to Bil Herd in Texas, Part will be shipped tommorow.
      Ralph
      Ralph Adams
      NCRS: 38137 LA: 112
      Slidell, LA 70461
        • 43221
        Ralph------
        Yes, there was another valve in there that I was unaware of. This one is for cars with manual control C-60. It's GM #10120965 aka Delco #15-5389. It's an odd-ball looking thing with a valve attached to an assembly which includes 2 fairly long tubes. This one's quite a bit more expensive than the 22532158, too. Also, I believe that it's been recently discontinued so I'm glad that you found one.
        • Ralph A.
          • May 31, 2002
          • 236
          Yes, 12.00 vrs 135.00 but when you need it.
          Thanks again for you help
          Ralph
          Ralph Adams
          NCRS: 38137 LA: 112
          Slidell, LA 70461
