66&63 327 Engines Pricing - NCRS Discussion Boards
  • Jeffrey Tatum
    I found out today that in my old wood boat that I have 327 corvette engines. I am thinking of selling them. What do you think they are worth. 63) cast 3782870 K213 66) cast 3892657 K46 Also iI would like to know if my other boat Has one casting 3756519 I269
  • Bill Braun
    Re: 66&63 327 Engines Pricing
    Jeff,
    I can't help you with the pricing - the Driveline is always helpful for that - but I believe you'll need the two-letter engine code to confirm whether you have Corvette engines or just Corvette valve covers. The Spec Guide states RC, RD, RE, RF, SC, SD as engine codes for '63 and HE, HH, HO, HR, HT, HD, HP, KH for '66.
    Bill Braun 33186
    • Gary Schisler
      I don't have my manual, but my memory cells are kicking around with the "657" 66 engine. The majority of 66 327 engines are "3858174". I seem to remember that the "657" may be one those engines that was "possibly used". I will check this out for a later post. Gary
      • Jim Mitchell
        The engine with the casting number 3756519, I269 is a 283. It was cast Sept 26, 1959, making it likely to have been in a 1960 vehicle. As with the 327s, you need to supply the two-letter code following the numbers stamped on the right front machined pad. I'm a 283 nut and would like to know what you're asking for this motor (I'm only interested in the block).
        Jim
