63 Master Cylinder snap ring removal - NCRS Discussion Boards
  • Steve D.
    • February 1, 2002
    • 990
    Car is 63, but I think the MC is 64. Drum brakes. Question_ How do you remove the snap ring to release the plunger and other parts? The snap ring has no holes for the pins of the snap ring pliers to slide into in order to compress the ring.
    Steve
    • 43222
    Re: 63 Master Cylinder snap ring removal
    Steve-----
    This type of snap ring in this type application should be illegal. Unfortunately, it's not. The only way that I know of to "extract" these is to use a pair of small screwdrivers or awls to pry them out.
    • Steve D.
      • February 1, 2002
      • 990
      Joe
      Thanks. That's the only thing I could think of, but I was hoping that someone might have a silver bullet.
      Steve
      • Verne Frantz
        Steve,
        If you manually push the plunger in, away from the snap ring, you should be able to grab the ring with a pair of bent needle nose pliers. Pull it toward the center, then twist it up gently.
        At least that's worked for me. Just make sure the ring is free in the groove first, not rusted fast.
        Also, before you push on the plunger, make sure you know which direction the outlet fittings are pointed. You're likely to spit brake fluid!
        Verne
        • Steve D.
          • February 1, 2002
          • 990
          Verne
          Thanks. I used a variation of that method. With the plunger depressed and the edge of the ring exposed, I used a dremmel tool and carefully cut a section out of the edge near the middle of the ring. When I pried on one open end of the ring, it broke at the cut and came out in two pieces. It worked well, but I think I'll get some bent nosed pliers and try your method next time.
          Steve
