Revisit; Colored fuses - NCRS Discussion Boards
  • Robert C.
    • December 1, 1993
    • 1153
    Gentlemen, While replacing my pannel light fuse for a Terry Mcmanmon test I came across my colored fuse collection. It states in a little piece of paper in the pack that the fuses are for 1965-1976 (All GM, I presume) the colors are as follows; Red-10amp ; white-25amp ; blue-15amp ; pink-4amp ; purple-3amp ; clear-28amp.
    • 15601
    Re: Revisit; Colored fuses..check again Bob
    Bob,
    I'll bet if you look again the clear one is 25 amp. I am not aware they made a 28 amp.
    Then again, I have had fat fingers more than once in a while too.
    • Tom B.
      • February 1, 1994
      • 779
      I would guess to say the clears were 20 amp. The 25 amps I have are white banded, which agrees with what Bob is saying for that one too. TBarr #24014
      • Robert C.
        • December 1, 1993
        • 1153
        Sorry guys I can't get anything past you. The clear are 20 amp! I thought thats what I typed but guess not. Bob
        • Joe S.
          • April 1, 1996
          • 28
          Ford also used color coded barrel fuses until they switched over to spade terminal fuses in the late 70's. There are ample supplies in almost any junkyard if you won't choke putting a Pinto fuse in your Corvette! I have fuses with the internal color band, AND COLOR CODED WRITTEN AMP DESIGNATION. I looked at my collection of Ford product colored fuses, and verified the following: white-25amp; clear-20 amp; blue-15amp; pink 4amp. The 20amp fuse also came color coded YELLOW. I have an assortment of other sizes, but they may not be of interest for Corvettes.
