C-1 Trunk Lock Ledge - NCRS Discussion Boards
  • Jimmy J.
    • May 31, 1988
    • 304
    What is a good way to make the protruding ledge over the trunk lock on a 1959? Should I use bondo, fiberglass or some other method? Where can I find a good picture of the protruding area? Thanks in advance. Jimmy
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Jimmy - Years ago I had pretty good luck...
    ...using bonding compound to build up the ledge, feeling it was stronger than bondo and easier to shape than fiberglass. There is a pretty good close - up picture in Nolands book that I used as a model. Came out pretty good...
    • Jimmy J.
      • May 31, 1988
      • 304
      Re: Jimmy - Years ago I had pretty good luck...
      Dennis, Do you remember the name of the bonding compound? Thanks for the response. Jimmy
      • Dennis A.
        • April 30, 1999
        • 1010
        Jimmy...
        Ecklers...good to have around and works well with Fiberglass.
        • Joseph T.
          • April 30, 1976
          • 2074
          Re: C-1 Trunk Lock Ledge
          Jim..I wonder if you could take a clay impression of the trunk buldge from another trunk lid and pour a mix of resin and fiberglass into it. Then bond and trim to the new trunk.
          Joe
          • Gene B.
            • May 31, 1990
            • 144
            Duraglass works well too. It works the same way as resin, but it already contains some fiberglass strans and it is very hard. Work well in this area.
            Gene
