Could someone post some photos of my stamp pad? - NCRS Discussion Boards
  • George W.
    • May 31, 2000
    • 544
    Please e me if you be so kind to post these for me. I promiss I will take the time to learn how to this myself soon. thank you, george
  • William O.
    • April 30, 2001
    • 355
    Re: Could someone post some photos of my stamp pad
    Sure, I will be glad to.
    Bill
    • George W.
      • May 31, 2000
      • 544
      Bill, e mail sent. Thanks, G.
      • William O.
        • April 30, 2001
        • 355
        RE: George's Stamp Pad (1)
        Photo (1)
        • William O.
          • April 30, 2001
          • 355
          Re: RE: George's Stamp Pad (2)
          Photo (2)
          Photo (3
          Photo (4)
          • William O.
            • April 30, 2001
            • 355
            Re: RE: George's Stamp Pad (3)
            • William O.
              • April 30, 2001
              • 355
              Re: RE: George's Stamp Pad (4)
              • George W.
                • May 31, 2000
                • 544
                Re: Thanks Bill--Please critique
                Okay all, please lend your thoughts/comments/observations/etc. I think I can see that the surface has been milled at a machine shop. The one photo shows a "shadow" or what looks like a double stamp, but that may have been caused by the camera flash, as this is not visible when looking at the pad with a magnifing glass. There is one more photo with a ruler that may help determine sizing. Thanks, G.
                • George W.
                  • May 31, 2000
                  • 544
                  Photos up--- please critique NM *NM*
                  • William O.
                    • April 30, 2001
                    • 355
                    Re: Photos up--- please critique NM
                    Photo (5)
                    • Kevin M.
                      • November 1, 2000
                      • 1271
                      George,
                      Background please. What do you know about this pad. Looking to buy, your's but never posted it before. Looks like it's been cleaned, steel wool, wire wheel. More info would help.
                      Kevin
                      • George W.
                        • May 31, 2000
                        • 544
                        Kevin, this is the block in my '65 FI cp. The pad was painted at one time and I used paint stripper followed by fine steel wool to remove most of the paint. The pad appears to have been surfaced (probably during a rebuild---my information from the previous owner of 22 years is that the rebuild was performed before he purchased the car?). All engine, body, vin, trans, rear end, etc. casting and stamped numbers/codes fit very well together on this car. I am looking for opinions concerning the pad stampings---look correct?---something amiss?---too deep/to wide/too straight/not straight enough/correct vertical and horizonal sizing/spacing? etc., etc. etc.. I have begun stripping the car for a repaint, and am considering going ahead with a body off, but thought I'd get some input on this pad before I purchase a fuel injection unit (car has no FI unit, has added side pipes, has added rear sway bar, has a '67 BB hood-----everything else, so far, looks original). I'm not sure what "Looking to buy, your's but never posted it before." means? G.
                        • Kevin M.
                          • November 1, 2000
                          • 1271
                          • William Liddle
                            The upset material around a stamped character will show up as a shadow under a flash and may look like a double stamp. Especially if the photo is taken from an angle and not straight on. With deeper stamping the shadow is more pronounced.
                            • William Liddle
                              George, it looks an awful lot like there is an upset around many of the characters which is common in medium to hard strikes. If this block has been decked then it was restamped after the decking. The machining operation would have removed all of the upset material from around all of the characters.
