Cleaning Aluminum Intake Manifolds - NCRS Discussion Boards
  • Larry E.
    • 1678
    Hello:
    Just want to get some ideas on how to clean an aluminum intake manifold with
    minor gas stains on it. The manifold has to be cleaned with it still intalled
    on the engine. What type of cleaning fluid will get this job done? Kerosine;
    some type of acid or ? Please advise and thanks for the help.
    Larry
    Larry
    LT1 in a 1LE -- One of 134
  • Steve Wallach
    Re: Cleaning Aluminum Intake Manifolds
    Spray "Brake Cleaner" works pretty good at getting oil and gas off anything. It will also take paint off and if you leave a rag laying on anything with brake cleaner on the rag, it will melt or damage it, so be careful with it, but it does work great as a "cleaner"...
    Steve
    • Christopher R.
      • March 31, 1975
      • 1599
      I used to get mine pretty clean with a toothbrush, Simple Green, and a garden hose.
      • William O.
        • April 30, 2001
        • 355
        I used a small steam cleaner and a toothbrush.
        FYI:
        The steam cleaner is great to clean everything, a great tool for detailing.
        • Wayne K.
          • December 1, 1999
          • 1030
          Larry,
          I've used the jell type paint stripper by 3M. It is easy to control. I apply it with a small paint brush then wipe it off with a paper towel followed with a soap & water wash. If you can get at the area with a toothbrush or other kind of brush work the stripper before wiping but be careful not to splatter.
          Wayne
          • Bryan L.
            • June 30, 1998
            • 397
            I've used Alumiprep with good results. You can find it just about anywhere.
            BL
            • Lyle B.
              • May 23, 2012
              • 17
              I have had a friend take theirs to a commerical acid dip company and they come out sparkling clean shiny.
              • Rob A.
                • December 1, 1991
                • 2126
                I had very good success cleaning the aluminum manifold in place on my '66 using lacquer thinner. It dissolves all the usual stains and evaporates quickly. Using Q tips you can get just about everywhere. It works well on alternators also. It leaves a clean, original finish.
                • Tracy C.
                  • July 31, 2003
                  • 2739
                  Q-Tips ?...
                  Rob,
                  How about filling a paint gun, narrowing the fan to 10 degrees and cranking the pressure to up 80 lbs? Seems like that would blast about any kind of crud to timbucktoo...
                  tc
                  • Rob A.
                    • December 1, 1991
                    • 2126
                    Re: Q-Tips ?...
                    You're probably right. (With the Q tips nothing blows around the engine compartment as it's being cleaned off the intake).
                    • Tracy C.
                      • July 31, 2003
                      • 2739
                      Re: Q-Tips ?...
                      AaaSooo... I wouldn't try my suggestion on an installed intake. I was thinking manifold "on the bench"... I gotta get my car back together so I can think straight... been looking at piece parts WAY too long..
                      tc
                      • Rob A.
                        • December 1, 1991
                        • 2126
                        Re: Q-Tips ?...
                        My last car was apart so long, I still can't believe it's finished, sold and gone. My ENTIRE 3 car garage, including ALL the cabinets were filled with parts.
