67' BB TRI-Power - NCRS Discussion Boards
67' BB TRI-Power
  • William O.
    • April 30, 2001
    • 355
    67' BB TRI-Power
    I just rebuilt my tri-power carbs and installing them.
    Question:
    What is the best proceedure to correctly installing the fuel lines and preventing them from leaks.
    Thanks.
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: 67' BB TRI-Power
    if the lines are new i would put a spare holley float bowl fitting in a bench vise and tighten each line into it to form the flare to the fitting. use never sieze on the gas line fitting threads to cut down on the friction and make the lines easier to get tight. teflon tape on the threads will also do the same thing just do not get any into the lines
    • Rob A.
      • December 1, 1991
      • 2126
      Definately use Clem's suggestions, especially if you're installing new lines and blocks. You'll be glad you did.
      • William O.
        • April 30, 2001
        • 355
        Thanks, I will try this tomorrow.
        Bill
        • Clem Z.
          • January 1, 2006
          • 9427
          i hope you did not buy stainless steel lines
          because they are almost imposible to get sealed because forming the flare work hardens the tubing and it will not conform to the seats in the fittings
          • William O.
            • April 30, 2001
            • 355
            Re: i hope you did not buy stainless steel lines
            They do look like stainless...What do you recommend,Do you know of a source?
            Thank you.
            Bill
            • William O.
              • April 30, 2001
              • 355
              Not SS
              FYI:
              I just talked Long Island, he said they are not stainless Steel.
              Thanks.
              • Clem Z.
                • January 1, 2006
                • 9427
                check the lines with a magnet,stainless should be non magnetic. you can check with the supplier you got these from
                • David G.
                  • December 1, 2002
                  • 99
                  Re: Not SS
                  The key is to get fittings to align perfectly. I purchased brand new set of steel lines and my father-in-law still had to spend time with small pipe bender reforming. If the fittings aren't straight they will leak no matter how tight you make them
                  • William O.
                    • April 30, 2001
                    • 355
                    Re: tri-power fuel lines installation
                    Installed the lines, only one small leak from the front carb, which stopped after a quick 1/8" turn.
                    Thanks everone.
