Non corvette wheels - NCRS Discussion Boards
Non corvette wheels
  • Joseph K.
    • March 1, 1980
    • 168
    Non corvette wheels
    A quick question, will 1970 Z28 rally wheels fit a 65 corvette hubs and leaving enough room for calipers? I know this is not the right forum but may be someone can give me an answer.. Would also like to find out paint code for wheel color............Thanks........Kirby
    • 43221
    Re: Non corvette wheels
    Kirby-----
    As far as caliper fitment goes, I don't think that they'll be any problem. The 1970 Z-28 wheels have the same, basic specifications as the 1969 Z-28 wheels. These wheels worked just fine for 1969 Camaros equipped with the JL-8 4 wheel disc system. Basically, this system used the same components as the 65-82 Corvette system.
    While the calipers and rotors should fit ok, the real problem may lie with wheel well interference. There is over a 1/2" difference in offset between the 1965 Corvette wheels and the 1970 Camaro Z-28 wheels. Depending on the tires used, that could present a problem.
    • Verle R.
      • March 1, 1989
      • 1163
      Kirby,
      I believe the Camaro wheel is a 15x7 with a deeper offset, that is, the wheel sets farther in. They should clear the calipers with no problem. There should be no interference problems on the fender, there may be interference inside depending on what tires are used. The tires may rub in the front on hard turns.
      Verle
