C2 Exhast Bezels - NCRS Discussion Boards
C2 Exhast Bezels
  • George C.
    • November 1, 2001
    • 568
    C2 Exhast Bezels
    As stated in my previous post I am installing under car exhaust on my 65. I have puchased repro exhaust bezels and they don't fit well at all. The curve of the flange isn't right, and the screw holes don't line up. I have an original exhaust panel, that just came off a car that was being converted to side exhaust. Does anyone know of a vendor that carries a repro bezel that fits well??
    Thanks again,
    George
    #36809
    • September 30, 1999
    • 710
    Re: C2 Exhast Bezels
    George, are you sure you have a 65 panel and 65 bezels. Mike
    • George C.
      • November 1, 2001
      • 568
      Mike,
      As sure as one can be. I purchased the panel from a fellow who converted his car to side exhaust and we believe the panel is the original. The bezels are repro for 64 - 65. The fit problem is with the curve of the flange, if I hold it tight at the top the bottom is raised off the panel about a 1/4 inch it appears it just doesn't have enough curve in it to follow the curve in the panel.
      George
      • Eugene B.
        • May 31, 1988
        • 710
        George,
        I just looked at my original '65 rear valance and bezels. They are not what I would call a perfect fit either. With all screws in place, there is about an 1/8" gap on both sides of the left bezel and about 3/16" gap around the bottom quarter on the right side.
        You may be unable to get a perfect, seamless fit.
        Gene
        • George C.
          • November 1, 2001
          • 568
          Gene,
          Thanks for the response, I put the panel on the car tonight and tried the bezels again. I probably have the same kind of fit you have, or not much worse than that. Mine are tight left to right, but 3/16 to 1/4 inch open top to bottom.
          George
