Help identify these 53-55 Parts - NCRS Discussion Boards
  • Kent K.
    • December 1, 1982
    • 1139
    Please help me identify parts in the attached photo.
    The relay with 3 connections at bottom is numbered 775, the last numeral is in question. What is it for?
    The relay with connections at 3 sides has number 988 on the back. What is it for?
    Is the pump for 1953 windshield washer system?
    The bracket baffels me although I remember it was for my '54.
    Thanks for your help.
    Kent 6201
    P.S. Roy, I haven't forgotten you offered but this could be an opportunity for others to learn something about early Corvettes.
    Kent
    NCM Founder - Member #718
  • Benjamin C.
    • July 31, 1994
    • 134
    Re: Help identify these 53-55 Parts
    The plate is the mounting bracket for the coil. It bolts to the engine under the ignition shielding.
    • Robert S.
      • July 31, 2004
      • 377
      The 775 is a horn relay, 988 is the neutral safety relay. The pump looks like the foot pump for the washers on '53s and I believe some very early '54.
      So how did I score?
      Bob
      • Roy B.
        • February 1, 1975
        • 7044
        56 57 washer pump missing ribber toe pad= but 3 speed 55 only used it
        Horn relay = having the two only holes
        starter relay= original and a Chevy over drive relay can replace it will work as a spare
        and bj is right
        • Roy B.
          • February 1, 1975
          • 7044
          BOB "neutral: safty switch Or relay is mounted on the trans.
          • Robert S.
            • July 31, 2004
            • 377
            You got me! I used the wrong terminology. I meant the starter relay on the firewall that is activated by the neutral safety switch on the trans when the gear selector is in park or neutral.
            Thanks for showing me the error of my way and keeping me on my toes
            Bob
            • Roy B.
              • February 1, 1975
              • 7044
              BOB I blow it all the time , no big deal
              • Kent K.
                • December 1, 1982
                • 1139
                Thank you B.J., Bob and Roy for your assistance. This is the first few parts of several that are now identified. You all scored Top Flight!!! The '54 was my first Corvette and I collected parts to restore it for about 13 years. Sold the car when we moved about 11 years ago (no place to keep it) and it was immediately restored and sold at auction during one of our Winter Regionals.
                Kent #6201
                Kent
