1965 Big Block Corvette - NCRS Discussion Boards
  • John S.
    • September 30, 1997
    • 263
    What are the key things that one should look for to help ditermine that a 1965 Corvette is a real big block car? The car presently has a 427ci 390HP engine.
    Thank you in advance for your inputs.
    John Sieczkos #29744
    • 43221
    Re: 1965 Big Block Corvette
    John-------
    This seems to be one of the most often posted questions on this board. There's probably a huge amount of info in the archives, much of it redundant. In any event, I'll add to the redundancy and mention these items:
    1) front stabilizer bar diameter (small block is 3/4"; big block is 7/8"; with F-40, both are about 1");
    2) presence of 9/16" REAR stabilizer bar; until 1975, ONLY big blocks got the rear bar regardless of suspension option;
    3) bolt-on style, nodular cast iron caps for the differential yoke axle u-joint retention; small blocks used u-bolts with nuts;
    4) configuration of engine end of the frame fuel line
    • Richard B.
      • March 1, 1989
      • 99
      also to dd what Joe said 65 BB are late cars
      • Mike M.
        • May 31, 1974
        • 8385
        TI, larger alum radiator, etc. mike
        • Wayne M.
          • March 1, 1980
          • 6414
          To add to the redundancy
          Like C60 cars, driver side battery with access door in inner fender; similar firewall harness and battery cable clips. Unique engine compartment ignition harness (due to alternator on left, without the extra wiring of the A/C harness). Instrument panel has LB sticker (same gauges as 365 or 375 hp engines).
          • Dave B.
            • April 30, 1984
            • 248
            John,
            Check the metal fuel line on the passenger side of the car that is at the frame. It should be 90 degrees for a BB, 45 for a SB. Also, as you may know, the 1965 big blocks were 396/425 cid/hp only.
            Our chapter put together a good document on discerning the differences, and I can email it to you if you would like.
            Dave
            • Charles M.
              • March 1, 2002
              • 155
              Don't hold me to it but while your car may have been a BB car originally the 427 was first offered in the 66 model year. 1965's had the 396cid engine.
              Chuck
                • 43221
                Chuck-----
                It's ok if someone holds you to it; that's how it was.
                • George W.
                  • May 31, 2000
                  • 544
                  Dave, I would like to have this information. Please forward when you can, thank you, George
                    VIN over 13,000 (unlike the one that went at B-J for $135K that was 10,000 cars too early)
                    • Tracy C.
                      • July 31, 2003
                      • 2739
                      those darn recreations anyway.... *NM*
