C2 Altenator Amps - NCRS Discussion Boards
C2 Altenator Amps
  • Larry M.
    • January 1, 2002
    • 538
    C2 Altenator Amps
    The Vette Vues Fact Book on pg 308 says base engines get a 37A and Hi-perf a 42A. Is HI-perf here a reference to big blocks. My 64 FI 375 HP has a 37A dated 3L6 or 11/6/63 for a car built 11/20/63 and I've assumed it was correct...but maybe it isn't. What is correct?
  • Steve Wallach
    Re: C2 Altenator Amps
    My 67 BB 390H (L36)has a 37A, it also has PW. I believe "Hi-Perf" refers to those with A/C or 400hp / 435 hp. My block says "Hi Per" cast into the block.
    It has the correct cast part number for my block also.
    Do you have the judging manual?
    I hope that helps?
    Steve
    • Bob R.
      • June 30, 2002
      • 1595
      The 375 HP engine used alternator number 1100669.
      • Michael H.
        • January 29, 2008
        • 7477
        Larry,
        While a 64 FI engine, or any other engine for that year, would have had a standard 37A alternator, the same engine with the optional transistor ignition would originally have had a 42A alternator. The same is true for any 64-67 with TI.
        Air conditioning equipped cars also would have required a higher amp alternator.
        • don 42616
          My 67 400hp has a correct 37A
          • Alan Drake
            Larry,
            Have a 64FI built 3/23/64 with K66
            Alternator is 1100669, 42A, date 3K3
            Its the original one. Hope this helps!
            • Dino L.
              • February 1, 1996
              • 694
              I think you should have (assuming no TI, because your car is too early for it) alternatory p/n 1100668 with stampings of 12V NEG and 37A and a date of 3L6...that is a 2 week window to car assembly, perfect...also with FI you should have the big pulley and Idler.
              Dino Lanno
