I have a 66 427/425 which I only occasionally drive. Last fall, 80 degree day, driving car, went about 5 miles, 55-60 mph, car started running rough like running out of gas. Died several times restarted and ran a few minutes each time until would not start and run. With air cleaner off could see fuel from accelerator pump when pumping carb. When starting car it would burn off gas that was pumped into carb with accelerator pump. If choke was held closed engine would run, but when it died there was no gas at accelerator pump either. Thought it might be vapor lock and let car cool a couple of hours. Tried starting it wouldn't run but after a few tries fired up and ran and drive fine. Ran fine the next several outings until today. Same symptoms, mid 70's temp. Engine compartment didn't seem very hot. Took loose fuel line to carb to see if fuel pump was working. It was working, didn't seem like a lot of presure, what does it call for about 5 -7 lbs??? Hooked fuel line back up, tried car and it started right up and is running fine. Any ideas???
Sorry for long description. Thanks
