Radio Campacitor # 1960958 Coil - NCRS Discussion Boards
  • Ray C.
    • June 30, 2001
    • 1132
    The wire broke loose from the capacitor and I have soldered it back to the capacitor. Measured the capacitance of the capacitor and it reads .477 micro farads. I believe this to be a .3 micro farads capacitor. Will this be a problem?
    Ray
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
    Re: Radio Campacitor # 1960958 Coil
    The coil caps were generally spec'd at 0.3 uF but with a reasonably 'sloppy' tolerance (perhaps 25%). Still, at 477 mic's, that's a LONG way from 300!
    I wouldn't sweat the difference, but I'd double check your meter as it's hard to 'grow' capacity that wasn't there originally! You'll find most of these 'hush up' caps run in the 0.2 to 0.5 mic range because they were designed to shunt AM based RF components, the AM frequency band is a fixed entity, and the car's wiring harness ground impedance profile is reasonably constant. Soooo, there's just not that much difference in the value of the cap you need to create a 'correct' low pass filter....
    But, if you'll sleep better with a fresh/new part, I think you'll find Long Island still has a healthy inventory of these mid-year coil caps with their unique integral 'one legged' mounting bracket.
    • Ray C.
      • June 30, 2001
      • 1132
      Thanks Jack
      Ray
      Ray Carney
      • Marc R.
        • April 1, 2004
        • 288
        I could understand paragraph 3 *NM*
        • Tony H.
          • May 31, 1993
          • 537
          Tony
