C3 virtual Dynamometers - NCRS Discussion Boards
  • Bryan Adams
    Does anyone know of a program or web site that I can plug my engine build into and have it tell me the Horse Power / Torque and all the good stuff?
    Engine: 454
    Split Moline end caps to convert to a 4 bolt main
    Bored .30 over
    10 / 10 crank dyno balanced on build.
    Deck plained
    Flat top notched pistons
    Older Chevy " peanut " heads
    3 way sodium filled valves
    double roller timing chain
    rocker rollers
    hooker headers and side pipes
    High rise eldebrock intake manifold
    750 double pump holly
    Eldebrock 510 lift 500 duration cam
    accell MSD ignition
    Munci M20 4 speed tranny
    And a alcohol based NOS system. (EVERYTHING IS BRAND NEW)
    I will never push it hard but interested in what she would do.....
  • Clem Z.
    • January 1, 2006
    • 9427
    go to www.chevytalk.org
    there are posters there that will "run" a dyno test for you.
      • 15674
      Re: C3 virtual Dynamometers
      In order to get accurate results, you need to know head flow, actual true CR, camshaft details, exhaust system backpressure, inlet system details, etc.
      Most programs only simulation SAE gross on a dyno, and SAE net with the engine installed in the car with the vehicle exhaust system and accessories can be much different.
      For this reason I prefer the Engine Analyzer program, which can simulate SAE net. It also takes some experience using these programs and correlation with actual dyno tests to refine your models.
      The best way you can find out what your engine is doing is run it on a chassis dynamometer.
      • David B.
        • July 31, 2004
        • 330
        I use the "Dyno 2000" program and am very satisfied with it. Besides telling you the HP and Torque (very accurately according to some magazine evaluations), it is really useful in making choices in planning an engine built (cam, CR, heads, etc.). I also modeled a friends engine (383 stroker) on it prior to the build and it actually dynoed right on target with the Dyno 2000 prediction when built. Good program - also there are many free downloads of plug-in information for cams and heads available at various websites.
        Dave, 1969 427, 1957
        Previous: 1968 427, 1973 454
        • Mark #28455
          peanut port heads?
          They are great heads for low RPM torque, but in a 454 application, they're all done by about 4000 RPM. If you're adding NOS, wouldn't you do better with a set of 049 or 781 casting oval port heads?
          Mark
          • Chris Ward
            Re: peanut port heads?
            "I will never push it hard but interested in what she would do....."
            There's your answer, which begs the question, why bother with the rest of the stuff if you're not gonna 'push it hard'? Is it just for lookin' at?
