I am redoing my brake/clutch support, and when adjusting the brake pedal, I run out of rod length for the clevis before the pedal shaft hits the rubber bumper. I am wondering if PB pedals are supposed to line up with the clutch pedal or are closer to the fire wall? That appears the only way to get the required 1/8 to 1/4 inch play.
Also, there was no brake return spring on the shaft when I pulled the support, and I have put a new spring on. Do PB 66 cars have the return spring? I see in the archives that 63-64 cars do.
The AIM is unclear about this. Thanks,
Dave
Dave
