Need help identifying block - NCRS Discussion Boards
  • Ralph A.
    • May 31, 2002
    • 236
    Car is 1969 build 11/28/69. Owner claims original engine. I suspect different. Block cast # is 3970010. Stamp pad has no vin number only V0108CKU. What can you tell from this.
    Ralph
    Ralph Adams
    NCRS: 38137 LA: 112
    Slidell, LA 70461
    1969 350/300 LeMans Blue Conv (restoring)
    1971 350/270 Bridgehampton Blue Conv (top flight)
    1972 350/200 War Bonnet Yellow Conv (restoring)
    2001 Bowling Green Metallic Conv (fun car)
  • Mike M.
    • May 31, 1974
    • 8389
    Re: Need help identifying block
    original block would have had the cars vin derivative. mike
    • Tom D.
      • September 30, 1981
      • 2134
      Sounds like a service replacement 350 - What is the casting date?
      TD
      https://MichiganNCRS.org
      Michigan Chapter
      Tom Dingman
      • Mike M.
        • May 31, 1974
        • 8389
        forgot to include the4 machine assembly data(which you state is on the pad) since there wqn't a vin, i didn't bother to look up the suffix which woould tell you what the block was originaly iontalled in or over the counter. mike
        • Ralph A.
          • May 31, 2002
          • 236
          The block is real dirty, rusty and the format does not fit the JM. It looks like A79. There is some round spots before and after.
          Ralph
          Ralph Adams
          NCRS: 38137 LA: 112
          Slidell, LA 70461
          • Ralph A.
            • May 31, 2002
            • 236
            Ins't that the V0108CKU?
            Ralph Adams
            NCRS: 38137 LA: 112
            Slidell, LA 70461
            • Mike M.
              • May 31, 1974
              • 8389
              V0108cku is referred to as the machine assembly data and CKU is the suffix which , if you have an old motor manual, will tell you what CKU was originally installed in. good luck, mike
              • Dick W.
                • 10483
                CKU comes us as being a 73 or 74 Camaro L 48 engine
                Dick Whittington
                • Tracy C.
                  • July 31, 2003
                  • 2739
                  Camaro? whooohoooo It's worth big bucks *NM*
                  • Jay Garris
                    CKU not CE block, After 60's suffix changed to 3 ltrs. on Camaros, Nova etc. Could also be a 73 0r 74 Nova or 76 Impala block All Th350 auto trans with HP at 170-185HP. Need to get a more definite read on dates.
                    • Ralph A.
                      • May 31, 2002
                      • 236
                      Re: Need help identifying block - Thanks
                      Well, at this point it will have to be replaced with at least a Corvette block and then possibly become a driver. A lot cheaper. The rest of the car seams original, carb, intake, A/C, Alt, trans.
                      Thanks for all this information.
                      Ralph
                      Ralph Adams
                      NCRS: 38137 LA: 112
                      Slidell, LA 70461
