C-3 A/C hoses - NCRS Discussion Boards
C-3 A/C hoses
  • Jeffrey S.
    • May 31, 1988
    • 1892
    C-3 A/C hoses
    I recently found an original aluminum A/C block with muffler (from the hose set that mounts to rear of the compressor) with no hoses attached. I found someone who can manufacture crimp on hoses but I need the correct length of the hose that goes from the inboard side to the POA valve. I would like to have the dimensions for both a small block and a big block early C-3 ('69, '70). The AIM list 2 numbers for small and big block so the length of this hose may be different for each. The hose for my '69 small block was cut shorter many years ago and I cannot use it to get a measurement. As always, thanks for your help.
    Jeff Salz
  • D S.
    • March 1, 2005
    • 1551
    Re: C-3 A/C hoses
    Email J. W. at AMC: jw@amcmfg.biz
    or call him at 1-800-900-9560
