(Message Deleted by Poster) - NCRS Discussion Boards
  • Darrell S.
    • January 1, 2004
    • 40
  • Harry Sadlock
    Re: 1964 tires
    Darrell, the worst radial made today is probably better than the best tire made in 1964. Saying that, you don't need to spend big dollars for tires.
    Just select the manufacturer you want, whitewall or blackwall and the best size is probably P205/75R 15.
    Harry
    38513
    • Darrell S.
      • January 1, 2004
      • 40
      Re: 1964 tires
      thank you Harry.
      • Verle R.
        • March 1, 1989
        • 1163
        Re: 1964 tires
        Darrell,
        If you want "reproduction" tires for your 64 done in radials, I recommend Diamond Back for the supplier. I have radials from Diamond Back with wide white walls and they have done well. A couple of friends with Coker tires have had significant problems.
        If you don't need/want "reproduction" tires just do as suggested, go to a local dealer and have 205 75 15s installed and drive on down the road.
        Verle
        • Donald M.
          • December 1, 1984
          • 498
          Re: 1964 tires
          Harry, it is generally accepted that radials with a speed rating of "H" or better are the most desireable tires for Corvettes, However, I have yet to find such tires in a 5/8" whitewall. It seems that all the speed-rated radials only come in blackwall. Does anyone have any info to the contrary?
          Thanx!
          • Darrell S.
            • January 1, 2004
            • 40
            Re: 1964 tires
            Verle..........thanks for the heads up!
            1
            • Patrick T.
              • September 30, 1999
              • 1286
              Just a suggestion.....
              But why isn't there basically the same message for the other side, except it would read....."Message Deleted by Administrator", instead of just disappearing?
              • James W.
                • December 1, 1990
                • 2655
                Re: 1964 tires
                Darrell,
                I bought Michelin brand Harmony 205/75-15, blackwall tires and love them. Went on the NCRS Road Tour last Summer with my '64 Corvette convertible and they performed excellent, very smooth ride and quiet. They are only an "S" rated tire, but do handle great for a driver Corvette. If you are looking to have your car judged, go with an OEM manufactured tire like the General Ameri GS4 blackwall radial. Good Year also make a white wall radial in the 205/75-15 size but I don'think the 6/10" white wall width is correct.
                James West
                  • 11643
                  Re: Just a suggestion.....
                  Next suggestion...
                  DON'T DELETE YOUR POSTS!!!!!
                  Rant off.
                  Patrick
                    Re: 1964 tires
                    Darrell -
                    You deleted your initial post, so I don't know what tires you have now, but if you're changing from bias-ply to radials, you'll need to have your front toe-in re-set, to zero-to-1/16" TOTAL toe-in. The rear should be re-set as well (to 1/32" per side, 1/16" total, split equally across the thrust centerline), but that can wait until your next 4-wheel alignment.
                    • Gary S.
                      • July 31, 1992
                      • 1632
                      Here we go again...
                      How about we edit and not delete? Like the earlier post, if it was worth typing in the first place, leave it.
                      I vote for administrator only deletes.
                      • Eric J.
                        • March 1, 1980
                        • 771
                        Re: 1964 tires
                        Had to put blackwalls on my 63 last year. They are Michelin X Radial 205 75 15s. Took awhile to get used to the sight of the blackwalls. They handle great. Smooooooth... Eric
                        • Darrell S.
                          • January 1, 2004
                          • 40
                          Re: 1964 tires
                          tnx ERIC..........nice car!
                          • Darrell S.
                            • January 1, 2004
                            • 40
                            Re: 1964 tires
                            tnx John Hinckley.
                            • Darrell S.
                              • January 1, 2004
                              • 40
                              Re: 1964 tires
                              Thank you ....James west...that was helpful.
