ZL-1 block ( rough casting ) on eBay - NCRS Discussion Boards
  • Steve Antonucci
    Here's a good one. Check out eBay Item number: 8044553424
    This is a rough casting of an original ZL-1 block. And,
    when I say rough, I mean rough. It comes complete with the
    Winter's foundry logo and '052 part number. As far as
    useable stuff goes, that's about it.
    This block is not milled in any way ( deck, mains, bores,
    lifters, oil passages, water jackets on the deck, internal
    threads on the decks, timing cover, oil pan rails, etc.).
    I'm sure there are other things that need to be done as well
    to this block.
    It's a nice conversation piece for the ZL-1 crowd, but how
    useable is it in the real world?
    So the question is really this. Could any shop actually be
    able to perform all of the milling required on this block?
    The oil passages alone need to be gun-drilled and that can
    be expensive. I looked into this once to convert a 2-bolt
    main block into a 4-bolt main block ( correct casting date
    & casting number ). I bet the milling costs would be
    astronomical to say the least assuming that it could be
    done dimensionally correct. You only get one chance with
    that much work.......
    So, assuming that all the planets were properly alligned and
    you were in-good the the big guy upstairs, could this block
    be machined properly today? All of the original setup
    tooling at GM for Mark IV blocks is probably gone by now.
    Actually, where were these aluminum 427 blocks machined back
    in the day? Was that work done in Tonowanda as well?
    Just wondering what others think about it.
    Steve
    • 43234
    Re: ZL-1 block ( rough casting ) on eBay
    Steve-----
    I would consider a block like this to be a "conversation" or "display" piece only. Very few, if any, machine shops would be equipped to final machine this block. If you found one that would, it would probably come at a high cost. One could buy a current generation ZL-1 block, fully machined, from GM for less overall. This block, built on the original tooling which has been modified and greatly improved, would be the ONLY way to go from a functional perspective. This block MIGHT be of value, though, to someone wanting to restore a Yenko car, providing that it has the Yenko casting insignias and the buyer has a source for machining. To me, this block would be worth about $100, maximum, as a conversation and curiousity item. That's all.
    As far as I know, original ZL-1 blocks were cast at Winters Foundry and machined at Tonwanda, NY. The current ZL-1 blocks are cast I don't know where and are CNC machined at Swartz Machine in Warren, MI. They are definitely not cast at Winters since, I believe that Winters went out of business with their parent company, Kaiser Aluminum. However, they may be cast at a successor to the Winter's foundry or at some other aluminum foundry.
      Low-volume block machining isn't cheap. My Viper blocks were cast by Ohio Aluminum and machined by Uniboring in Livonia, Michigan, on three six-axis Mazak CNC machining centers with automatic tool changers. That setup generates about two blocks per hour per machine, and the washer that cleans them after machining was $250,000 (we paid for the tooling and facilities at Uniboring).
      • Steve Antonucci
        Joe,
        I agree completely. A nice door-stop huh?
        BTW, no Yenko or any other "day-two" car ever came with a ZL-1 block.
        They were all standard L/72 iron blocks. Even the aluminum blocks that
        Don Yenko had cast ( with the Yenko name in place of the Winters foundry
        logo ) were all available way after the 69 production year.....
        Steve
        • Steve Antonucci
          John,
          I'd love to know the cost per block for complete setup, machining & cleanup.
          Do you have a ball park figure?
          Also, what condition are your Viper blocks in pre-machining? Are they rough
          castings as the example ZL-1 block in this thread?
          Steve
            Steve -
            As I recall, we paid around $1800.00 per block for the machining; there was only one setup per block, and the Mazaks did all the re-positioning and tool-changing automatically. Two smaller Mazaks did the heads, oil pan, and front cover. The raw castings from Ohio Aluminum (block, heads, oil pan, front cover and water pump) were similar to the block in the auction, but were much crisper and cleaner without all the excess material.
              • 43234
              Steve-----
              Yes, as far as I know, no Yenko Camaros ever received one of the aluminum Yenko blocks. However, I was told that some of the later Yenko Chevy IIs did have them. I don't know if that's true, or not, since I don't really study other Chevrolet models in a lot of depth and I have virtually zero interest in Yenko cars of any sort. However, if it's true that NO Yenko-badged cars ever included the aluminum big block, then I don't know why someone would pay a king's ransom that I've seen paid for these blocks on eBay from time-to-time.
                • 43234
                John-----
                Yes, and I would expect that when "low volume" gets down to a single piece, the cost really gets out-of-hand. I can just imagine what it would cost to have a capable machine shop with CNC milling equipment set up to machine a block like this unfinished one under discussion here.
                • Steve Antonucci
                  Joe,
                  That's another ditto!
                  Just the name Yenko seems to put people into a tailspin.......
                  As you mentioned, I've seen people pay major bucks for Yenko crested aluminum
                  427 blocks that the sellers had all kinds of claims about being in original
                  Yenko cars. Just not true. Even if you want it to be so, it just isn't....
                  Steve
                  • Joseph T.
                    • April 30, 1976
                    • 2074
                    Joe
                    I saw a ZL1 engine while in Florida for the Regional Meet..with what appeared to be the original vin # stamped on it from the plant that made Camaro's...based on the vin #.
                    Can't remember all the details...but it looked real as can be..was not for sale ..just one great item in an awesome collection...of cars and parts. Owner is a serious guy.
                    When I was a teenager living in Chicago..there was a street racer that had an unbeatable Camaro with a ZL1. Many moons ago. Does not mean either one was a Yenko.
                    • Michael H.
                      • January 29, 2008
                      • 7477
                      Could be you are remembering Art Bovio? He had one of the Gibbs ZL-1 cars. Bought it new but if I remember correctly, it was a dealer trade from Gibbs to a dealer in the SW suburbs.
                      • Joseph T.
                        • April 30, 1976
                        • 2074
                        Michael..this was an inner city racer..as I remember called Junior. At that time 69/70 there was the High Chaparall and the Coke Machine Camaro's and I think Junior's was a 3rd car.
                        Races were on Hall street. Did not see too many Corvettes mostly Chevelles, Camaro's, Mopars
                        • Steve Antonucci
                          Anyone care to hazzard a guess as to what it would cost to get this casting
                          finished machined ( including cylinder sleeves ) into a state ready for final
                          assembly? Could it even be done at this late a state?
                          Steve
                          • Michael H.
                            • January 29, 2008
                            • 7477
                            I remember the Coke Machine from Lyons?(Al Cocanis?) but I don't remember Junior. I remember some great street racing on Ogden Ave just east of the Chicago city limits that headed west and ended at the Cicero line. The shut down was actually in Cicero. Chicago cops got paid off most of the time. If not, they opened several fire hydrants and flooded the streets so there was no racing. Of course, mikey wouldn't have been involved in anything as sinister as this.
                            • Joseph T.
                              • April 30, 1976
                              • 2074
                              Michael..those days would make a great movie..or has it been done with ricers? Ever wonder where all those cars went?
                              I suspect the old neighborhood alley garages are loaded with muscle car gems..and a few Corvettes too.
                              I do rememember an L88 losing its rear end at US30...too bad we don't have a picture history of that time frame.
