A few plating questions.... - NCRS Discussion Boards
  • Jeffrey S.
    • May 31, 1988
    • 1882
    Re: A few plating questions....
    Donald:
    If memory serves me I removed the old plating (which was pretty well gone anyway) by simply wire wheeling. I use my drill press set at a medium speed and put the wire wheel on an arbor and mount it in the chuck. Any rust I would remove by soaking in phosphoric acid.
    Jeff
    • Harold# 43147
      You will never get the correct color on a Qjet body using Caswell Yellow Chromate. Qjet bodys are cast from (Zamak3) which is a zinc Alu. composition. Rochester used a Zinc Dichromate Conversion solution to put this color on. This was used to protect the casting from corrosion. The other products should work fine there is a lot more to it than people think. Hope this helps
      • Greg L.
        • March 1, 2006
        • 2291
        #18
        Harold, would you happen to know how to replicate the quadrajet housing finish?
