C3 sill plates - NCRS Discussion Boards
C3 sill plates
  • Bill E.
    • April 1, 2003
    • 200
    C3 sill plates
    The black paint in the valleys of the repo sill plates on my '74 driver started peeling off. I know I can replace them for about $40.00 with another set of repo's but I'm cheap and it's Winter here in New England and I need something to do. So, I removed the remaining paint with lacquer thinner and now have a shining set of sill plates. Has anyone tried painting these? I was thinking of masking off the top of the ribs and then wipe off any overspray from the top with a lacquer wetted rag. Any ideas? Thanks, Bill
  • D S.
    • March 1, 2005
    • 1551
    Re: C3 sill plates
    After you've diligently worked three hours going through all that you might find $40 a good deal. I never had any luck repainting those things and I'm told I'm pretty good at detailing.
    Upper 70s in Texas.
      • 11649
      Re: C3 sill plates
      Bill,
      Use self-etching primer, then hit them with SEM Trim Black.
      I usually tape off the high spots that I don't want painted. I then remove the tape after I've used the primer and color coat. The sharp edge of an X-acto knife blade works well to "knock off" the high spots of paint, and then I follow with a rag that has a little lacquer thinner on it.
      Works like a charm.
      Patrick
      • Chas Henderson #28127
        Re: C3 sill plates
        I taped off the sides. Painted them, then took steel wool and cleaned the upper areas. That was several years ago and they still look great.
        Chasman
