C-3, PO2s - NCRS Discussion Boards
C-3, PO2s
  • D S.
    • March 1, 2005
    • 1551
    C-3, PO2s
    I was under the impression that the '68 PO2s had the flatter center emblem and '69 up PO2s had the raised, heavier chromed center emblem. On several auctions on eBay there has been references to the contrary. Which please?
    Scott
  • Paul O.
    • August 31, 1990
    • 1716
    Re: C-3, PO2s
    Scott the 68 P01 Looks alot like the P02 but there are differences like the P01 center cap extends out beyond the turbine fins where they join and the turbine fins are pointed at this point also. The P02 the center cap is slightly smaller at the same joint and the fins are flat and squared off not pointed. That is the quickest way to see the difference other then that they are the same. Paul
