C3 (72) LT1 half shafts - NCRS Discussion Boards
  • Rob C.
    • August 31, 2004
    • 144
    Could some one send or post a picture of the half shaft and it bolted up to the diferential. I have two diferent yokes on mine and want the same.
    Thank you, Rob
  • Chuck Caldwell
    Re: C3 (72) LT1 half shafts
    Rob,
    Your differential yokes for the LT-1 should be the "threaded" HD type that uses the heavy duty "caps" for the U-joint connections that bolt directly to the yokes. The LT-1's used the HD yoke and cap setup, like the big block cars.
    Sounds like someone may have broken one of the yokes at one time in the life of the car (probably doing hole shots/racing) and replaced one of them with the wrong type.
    The correct replacment parts are readily available..
    Hope this helps..
    Chuck
