70 LT1 suspension - NCRS Discussion Boards
70 LT1 suspension
  • Dennis D.
    • March 1, 2000
    • 1071
    70 LT1 suspension
    Did 70 LT1 have large diameter halve shafts? Was F41 suspension standard?
  • Jim T.
    • March 1, 1993
    • 5351
    Re: 70 LT1 suspension
    Does your 70 LT1 have bolted caps for the half shaft u-joints? My 70 (not a LT-1) does and it has the large diameter half shafts. The ZR1, only 25 ordered, came with special springs, front and rear stabilizer bars. The F41 suspension was not a separate option in 1970.
    • Dennis D.
      • March 1, 2000
      • 1071
      Thanks Jim...
      My 70 is a L-46. Looking at possibly adding an LT1. All seems correct, but the suspension and halve shafts appear as my L-46.(standard issue). Couldn't remember if that's right.
        • 15621
        To the best of my knowledge, in 1970 there is only one diameter half shaft -- regardless of engine. There are other features -- type of universal joint cap and shot peening -- that are different depending on engine option -- but diameter is not one of the variables.
          • 43259
          Terry-----
          That's how it is. ALL 1963-74 Corvettes use half shafts of the same tube diameter. The larger tube diameter half shafts did not appear until 1975 and were used for all applications thereafter.
