C2 Cluster - NCRS Discussion Boards
C2 Cluster
  • Mark H.
    • July 31, 1998
    • 384
    C2 Cluster
    What is a good match for the green paint used on the back side of a C2 cluster housing?
  • George C.
    • November 1, 2001
    • 568
    Re: C2 Cluster
    Mark,
    Check the archives, I posted some Krylon numbers that I used when I did mine. It was not a 100% perfect match, but pretty close. If you can't find it in the archives, I will see if I can find the rattle cans and post again, BTW there are two differenct colors of green needed.
    George
    #36809
    • William O.
      • April 30, 2001
      • 355
      Re: C2 Cluster
      I don't think this is a paint, I have a Jan 1, 67 and it looks like the metal is aged and have develeloped a patena finished.
      • Gordon Peterson #4961
        Re: C2 Cluster
        Maybe something changed over the years - so many things did. At the other end of the C2 time line, my '63 is definitely light green paint complete with minor overspray.
        Pete
        • Scott Marzahl
          Re: C2 Cluster
          I found a Laura Ashley Heather Green that matched very, very close. I haven't seen that designer brand at Lowes lately though.
          • Mark H.
            • July 31, 1998
            • 384
            Re: C2 Cluster
            I checked and found your posts, but didn't see any numbers. Just that you had found some green that worked.
            • George C.
              • November 1, 2001
              • 568
              Re: C2 Cluster
              Mark,
              Hi, here is what I found in the gargae, now I am not sure which I used. For the light green look at; Krylon Satin Jade number 3509, or take a look at Rustoleum Satin number 7720, guess I should have taken notes, it has been a couple of years. For the dark green I used Painters Touch by rustoleum number 1938 Hunter Green. Good luck with your project.
              George
