71 radiator - NCRS Discussion Boards
71 radiator
  • Boyan B.
    • August 31, 1999
    • 189
    71 radiator
    Can anyone look up in the Judging Guide what is the correct radiator for a 71, 270 hp (base) 4sp with A/C? I need to know what material it's supposed to be made of, part numbers and dates if needed, etc. Thanks.
    Boyan.
    • 43202
    Re: 71 radiator
    Boyan-----
    I don't have a 71 JG handy, but I can tell you what you need. The radiator used with your application is a copper brass radiator of GM #3018803. The key factor here is the WITH A/C. Without AC, your application would use the aluminum radiator, GM #3155316. However, "WITH A/C" it changes to the copper brass radiator.
    The use of the 3018803 copper/brass radiator also changes a lot of other things. The radiator support was GM #3966594 and the fan shroud is the plastic fan shroud of GM #3956109. The upper and lower radiator hoses are also different than would be used with the 3155316 aluminum radiator.
    Last but not least, the 3018803 radiator uses NO external supply tank; rather, it has an integral filler neck on the right side tank. The 3155316 aluminum radiator used for base engine with 4 speed and WITHOUT A/C does use an external supply tank.
    • Boyan B.
      • August 31, 1999
      • 189
      Re: 71 radiator
      Thanks Joe, thats what I needed.
      Boyan.
