IGNITION SWITCH CONNECTOR ISSUE - HELP! - NCRS Discussion Boards
  • Ernie DeVincent
    I am replacing my standard (non tilt/tele) steering column with a rebuilt tilt/tele column. Have noticed that the ignition switch and vehicle harness connector is different between the two.
    The vehicle harness will only connect to my old (non tilt) ignition switch. I assume if I simply swap the switches from the old column to the new that things will not work correctly.
    What do you suggest???
    Thanks!
  • Robert S.
    • July 31, 2004
    • 377
    Re: IGNITION SWITCH CONNECTOR ISSUE - HELP!
    I suggest you list the year of your in the subject line, then we would know what your talking about.
    Bob
    • Terry F.
      • September 30, 1992
      • 2061
      Is one of your connectors curved and the other straight? Terry
      • Dick W.
        • 10483
        There is a difference in ignition switches from std to T/T. Dash harnesses are the same. I assume that you are working on a 69-76 car?
        Dick Whittington
        • Terry F.
          • 2061
          There is a wire harness adapter on ebay that allows you to connect between the curved harness connector and the straight harness connector. Thanks, Terry
