'62 340 hp carb base gasket/s... - NCRS Discussion Boards
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    I would appreciate it if someone with a little '62 knowledge would describe exactly what gasket/s go between the carb and intake - and material if other than normal stuff. Thanks, Dennis
  • Mike E.
    • February 28, 1975
    • 5139
    Re: '62 340 hp carb base gasket/s...
    Dennis--
    No bakelite block, no stainless heat shield on the 340--just the gasket. 300 HP used all three.
    Mike
    • Dennis C.
      • January 1, 1984
      • 2409
      Thanks Mike... *NM*
      • Christopher R.
        • March 31, 1975
        • 1599
        All the usual Corvette vendors carry this gasket. But only Dr. Rebuild carries one with a "tab." Not sure if the tab is correct or not. But he says it is.
