alt rebuild - NCRS Discussion Boards
alt rebuild
  • Stephen W.
    • March 1, 2002
    • 301
    alt rebuild
    Found a correct date coded alternator with 37A & correct part # for 64 l-75 no a/c
    This is a good core but has not been tested.
    My question is how to prep the case to bring it back to look the best it can. I've been told not to bead blast it.
    Another problem is someone used sandpaper to scuff the surface where the numbers are. Not deep but they did shine up a spot about 3" long by 1"
    Rebuilding the alternator is not a problem for me but restoring it back to a factory fresh look is something quite different.
    Can I buy date coded diodes?
    Can I use the internals from my 60A alternator on my car now?
    Is it better to farm this out to get the look I want?
  • William O.
    • April 30, 2001
    • 355
    Re: alt rebuild
    Send it to John Pirkle 706-394-9047 you will be absolutly glad you did.
    • Gerard F.
      • June 30, 2004
      • 3806
      Re: alt rebuild
      Steve,
      Take a look at this thread:
      Eagle Mag Cleaner (etching formula) does a decent job, and you can use the stator and rotor from a replacement 60-61 amp in it. Not sure about the dated diodes availability. Caution on cleaning the diodes, the date code comes off easy.
      Jerry Fuccillo
      #42179
      Jerry Fuccillo
      • Stephen W.
        • March 1, 2002
        • 301
        Thanks to all! *NM*
