63 T10 - NCRS Discussion Boards
63 T10
  • Jerry DiTullio
    63 T10
    Was the main housing of a 1963 T10 tranny painted semi-flat black and the tail housing raw aluminum? Please advise...Thanks
    • 43203
    Re: 63 T10
    Jerry-----
    I might be incorrect on this, but I believe that the T-10 aluminum main cases were natural aluminum, just like the extension housing. The appearance of the surface is different, though, because the main case is a sand casting whereas the extension housing is a permanent mold or die casting.
    • William C.
      • May 31, 1975
      • 6037
      Re: 63 T10
      Joe has it right, it was also a T-10 1D case which required a small diameter bearing on the input shaft and a '421 bellhousing, all used in 1963 ONLY.
      Bill Clupper #618
      • Mike M.
        • May 31, 1974
        • 8377
        Re: 63 T10
        you don't have an incorrect for 63 cast iron case by chance? as joe and clip stated, the 63 t-10 case was aluminum. mike
          • 15643
          Re: 63 T10
          Was the wide ratio T-10 iron cased in '63? I recall that at least some of the wide ratio T-10s had iron main cases, but maybe not on Corvette.
          Certainly the '63 CR T-10s were aluminum cased with no paint of any kind.
          • Mike M.
            • May 31, 1974
            • 8377
            Re: 63 T10
            duke: i believe the cast iron case said goodby to corvettes in early 61 production year. mike
              • 43203
              Re: 63 T10
              Duke and Mike-----
              ......and, goodbye to other Chevrolet cars, too.
                • 15643
                Re: 63 T10
                Joe - so what was the last year of the iron case T-10 for various models, both CR and WR?
                  • 43203
                  Re: 63 T10
                  Duke-----
                  As far as GM applications go, it was mid-to-late 1961 model year (phased in). By 1962, all cast iron T-10s were gone from GM applications. However, T-10s were also made for other car manufacturer applications. Some of those may have continued with a cast iron case after 1961. It seems to me that some Ford applications continued to use cast iron cases after 1961, but I'm not sure about that. I don't follow Ford and Chrysler that closely.
                  • Mike M.
                    • April 30, 2003
                    • 104
                    Re: 63 T10
                    In 1976 I took the engine and transmission out of a junked 1963 F-85. The car was an original 4-speed car and had a cast iron cased, aluminum extension housing, wide ratio t-10. I got the whole works (215 cid, 4bbl/ 4-speed) for $100. Put the engine in a Vega and sold the T-10 for $100. Junkyard was off Parr Blvd in Richmond, CA.
                    Mike
                    • William C.
                      • May 31, 1975
                      • 6037
                      Re: 63 T10
                      Also Pontiac and I believe Buick used the iron case past '61, 62 for sure and I believe into '63.
                      Bill Clupper #618
                      • Mike M.
                        • May 31, 1974
                        • 8377
                        Re: 63 T10
                        clup is correct . the oldsmobiles also continued the use of cast iron cases past 61. worked in a junkyard in Mt Morris Pa while in med school and my job was to make a good 4 speed out of busted up 4 speeds. Cadavers didn't mind greasy fingernails.mike
                        • Verne Frantz
                          Re: 63 T10
                          I think you'll also find them with iron cases in a few Studebakers.
                            • 43203
                            Re: 63 T10
                            Mike-----
                            OK, perhaps I got too "global" in saying that cast iron cases were eliminated from all GM applications by 1962. I should have said they were eliminated from all Chevrolet applications by that time.
                            • Mike M.
                              • May 31, 1974
                              • 8377
                              Re: 63 T10
                              no problem joe. you've forgotten more than most of us ever knew. regards, mike
