C2:67 Washer Hose Clip - NCRS Discussion Boards
  • Gerard F.
    • June 30, 2004
    • 3806
    I've got this little repro clip which is supposed to hold the washer hose from the reservoir to driver side hood latch. Looking at the 67 AIM (non AC, SB), there is no way that the clip is attached to the hood latch as shown.
    Does somebody have a picture of a correctly attached clip.
    Also looking for a picture of the correct orientation of the YA tag on the master cylinder bail.
    Thanks in advance.
    Jerry Fuccillo
    #42179
    Jerry Fuccillo
    Re: C2:67 Washer Hose Clip
    Jerry -
    That clip (3827371) is the same one that's used to secure the headlight harness to the flange on the front of the radiator support, and was also used to retain the antenna cable inside the open "U" section on the front side of the lower instrument panel reinforcement behind the cluster. It's NOT the same "S-clip" used in many other applications. Photo below shows it on the hood latch in the washer hose application. The photo doesn't show the "YA" tag, but I put mine on the inboard side of the rear bail wire.
    • James W.
      • December 1, 1990
      • 2660
      Were those clips used on 1963 through 1967 or just 1967, both for the washer hose and headlight wiring harness???
      James West
      • Tim E.
        • April 1, 1993
        • 360
        Same clip, same location for my '66. Tim
          The washer hose/hood latch usage must have started in '66 - not shown in the '65 A.I.M. for that location.
          • Donald M.
            • December 1, 1984
            • 498
            Jerry, The YA label does indeed go on the rear bale. I had a problem with the label sliding down the bale wire and wrinkling. So, I used a small dab of silicone sealer between the "loop" of the label and the bale applied with a paper match stick and it has held fast since then. The silicone, being clear does not show.
            • Gerard F.
              • June 30, 2004
              • 3806
              John, I knew I could count on you, thanks.
              I know you posted this one before but I just noticed the clip. The 67 AIM sketch had me all screwed up.
              Jerry Fuccillo
              Jerry Fuccillo
