C2 Babba has been in my Steering Column, Help!! - NCRS Discussion Boards
  • Nick Mesich
    Re: C2 Babba has been in my Steering Column, Help!
    Nick -
    The horn button (pre-Bubba) pops right off - it's only retained by the nine spring fingers on the horn contact assembly; then you remove the three screws that attach the horn contact assembly to the steering wheel hub, and you can then remove the steering wheel. The telescopic arrangement is a little different once you pop the horn button off. Both designs are shown in detail in your Assembly Manual - in UPC 12 for the standard column, and in section N34 for the telescopic column.
