C- 2, K-19 check valve restoration - NCRS Discussion Boards
  • Dale S.
    • November 12, 2007
    • 1224
    Does some one have a recomendation for the rebuilding and restoration of my 5361992 and "Y" K-19 check valves. Thank you in advance. Dale
    • 43221
    Re: C- 2, K-19 check valve restoration
    dale-----
    I don't think that these check valves can be rebuilt. However, they can be re-finished. They can be easily tested, though, by blowing through them in each direction. From the threaded end, there should be no passage of air. From the hose end, air should pass freely.
    In a functioning AIR system, these valve MUST work properly. Failure of the valve to prevent backflow (which is the failure mode of these valves) will result in the destruction of the diverter valve and/or pump.
    Bill Hodel would be the one to contact regarding these valves.
    • Dale S.
      • November 12, 2007
      • 1224
      Thank you Joe. I will call Bill H. Dale
      • Gerard F.
        • June 30, 2004
        • 3806
        Joe,
        What's the correct finish for Dale's K-19 valves.
        Jerry Fuccillo
        Jerry Fuccillo
          • 43221
          Jerry------
          Zinc plated with a dischromate (gold) overplate. Original valves of the period had a more-or-less "dull gold", "satin finish". Later examples of SERVICE valves were a MUCH brighter gold and VERY shiny.
          • Gerard F.
            • June 30, 2004
            • 3806
            Sounds like original carb finish
            Put them in the mail, Dale. I see another fun project coming up.
            Jerry Fuccillo
            #42179
            Jerry Fuccillo
