wire harness 1963 dash brace - NCRS Discussion Boards
  • Ray C.
    • June 30, 2001
    • 1132
    Does the under dash wire harness run above or below the support rod brace near the defrost duct?
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
  • Joe M.
    • February 1, 2005
    • 590
    Re: wire harness 1963 dash brace
    Ray,
    Harness is above the brace on my car.
    joe
    • Ray C.
      • June 30, 2001
      • 1132
      I thought it was, but wanted to make sure prior to mounting the dash unit.
      Thanks for you help!!
      Ray
      Ray Carney
      • Stephen L.
        • May 31, 1984
        • 3158
        Isn't there supposed to be insulation glued to the firewall. There is on a '67. Can't vouch for a 63, but now would be the time to install it
        • Ray C.
          • June 30, 2001
          • 1132
          Hi!
          Steve
          Yes there is and it has a black asphalt type covering and it is installed just below the view you are looking at.
          Thanks for asking!
          Ray
          Ray Carney
          • Stephen L.
            • May 31, 1984
            • 3158
            Ray, the stuff I am talking about is "glued on" insulation above the black stuff. It has no "backing" just insulation. Its right under the windshield opening and above the heater housing. maybe it was used in later years. Mine is a '67.
              The upper cowl plenum insulation looks like this (heater box was a test fit - main dash mat/insulator not installed yet).
