1969 big block id - NCRS Discussion Boards
1969 big block id
  • jim ethington
    1969 big block id
    Question, I am going to look at a 69 convertible this week that is supposed to be a big block car with the wrong motor. What would be some things to tell big block from small block car? Rear end etc. Thank you.
  • William O.
    • April 30, 2001
    • 355
    Re: 1969 big block id
    I would look at some the obvious:
    Rear end codes.
    Half shafts/u-joints (steel caps Vs "U" Bolts).
    Rear Stablizer.
    Front Sway bar size.
    • Dick W.
      • 10483
      Tachometer red lines
      350-300 hp 5300
      350 hp 6000
      427 390 5600
      400 5600
      435 6500
      430 6500
      Dick Whittington
      • William O.
        • April 30, 2001
        • 355
        Oil pressure gauges:
        327 300 = 60
        327 350 = 60
        427 390 = 60
        427 430 = 80
        427 435 = 80
        • jim ethington
          In regards to the front sway bar, what sizes were they? Thanks
          • William O.
            • April 30, 2001
            • 355
            3/4" Small block
            7/8" 427 Std. Base
            &/8" 427 L36/L68
            15/16 F-41 HD
            • Dick W.
              • 10483
              All 69 oil pressure guages 70#
              Dick Whittington
              • Mark #28455
                sorry, you're thinking mid-years
                For 1969, all the oil pressure gauges are the same. Also, the small blocks had a 3/4" front and no rear bar and all big blocks had a 15/16" front and a 9/16" rear bar.
                Mark
                • William O.
                  • April 30, 2001
                  • 355
                  Re: sorry, you're thinking mid-years
                  Your right...I was stuck in mid-year data..
